Cutout lubricant?
Old 02-24-2012, 04:58 PM
RebelExtrm02's Avatar
Question Cutout lubricant?
What would be the best thing to use to lubricate the moving parts of a cutout after cleaning it? Given the heat it is exposed to, I'm not sure what to use.
Old 02-27-2012, 09:28 PM
onebaddmax's Avatar
How about a thin coat of never seize?
Old 02-27-2012, 09:52 PM
01ssreda4's Avatar
I like chain lube. Like for 4 wheelers. I use that crap on everything. It works great.
Old 02-28-2012, 12:09 AM
bww3588's Avatar
Chain wax. Comes in a spray can. Sticks to everything for a long time so watch what you get it on.
Old 02-28-2012, 12:11 AM
blacknyellow's Avatar
+1 for chain lube, or just grease. high temp grease
ANTICOP RAM AIR's Avatar
Bar&Chain for a chainsaw or Chainwax for MotoX... I have both and they work well for weathered use...
Old 02-28-2012, 01:33 PM
Where would be the best brick and mortar place to find chain lube/wax? Can it be found at Walmart or should I venture out to a Lowes/Home Depot/Sears?
Old 02-28-2012, 04:22 PM
01ssreda4's Avatar
I buy mine from the auto parts store.
Old 02-28-2012, 05:46 PM
Moderator
jimmyblue's Avatar
I like engine assembly lube for a lot of things, it's basically a graphite
loaded grease.
My cutout gearbox was too crusty to get opened up, I used Lock-Eze
(spray graphite) to do what I could on the butterfly shaft. But you
want to get the gearbox greased if you can.
Old 02-28-2012, 06:12 PM
bww3588's Avatar
I get chain wax at ATV/motorcycle dealers.
Old 02-28-2012, 06:17 PM
jrane's Avatar
I used the Chain lube and White lithium grease (WD-40) both have worked good for me
Old 02-29-2012, 12:53 AM
ls1 1990 VN's Avatar
Over here we have a copper graphite grease I would use on on my chevy motored Jet boat exhaust manifold bolts, was brilliant in that they never seized up.
Quick Reply: Cutout lubricant?
