NastyPerformance Aluminum catch can
Noticed alot of people looking for a catch can so we made one. Just in case anyone was interested.
Over Flow Tank
1 quart capacity aluminum construction
1/4 NPT top and bottom
$44.99
http://home.comcast.net/~ls1-com/Ima...f_catchcan.JPG
Nate
Over Flow Tank
$44.99
Nate
Nate, I see in your post over at the Sponsor GP section you mention it can be used as a oil can, if you have a fitting on the top and one on the bottom I can't see it being used for an oil catch can. JMO
Al
Al
Senior Member
Al
Al
I would think you would have the input hose connected toward the bottom and the output toward the top as gravity should pull the oil down to the bottom of the can, away from the intake port, and at the very bottom there would be a drain tap(if accessable).
Restricted User
I am wondering why ol Nate is not giving more detail. WHAT IS THIS THING AND HOW DO YOU EXPECT IT TO WORK????? This looks like a small muffler. Please Nate, go into some detail on your product. I can tell that it is not billet aluminum. If you are the man that designed it, you should be able to explain how this works, I know Todd can tell you a lot about his product(AMW catch can).
I made a simple can with 2 fittings one in one out. If it does not work for your setup I appolojize. I will see about making one with 2 fittings at the top but it will be a while I have them all polished.
Nate
Nate
