NastyPerformance Aluminum catch can
Old Mar 22, 2004 | 11:20 AM
Nasty N8's Avatar
Talking NastyPerformance Aluminum catch can
Noticed alot of people looking for a catch can so we made one. Just in case anyone was interested.
Over Flow Tank
1 quart capacity aluminum construction
1/4 NPT top and bottom
$44.99
http://home.comcast.net/~ls1-com/Ima...f_catchcan.JPG
Nate
Old Mar 22, 2004 | 11:48 AM
Smoke T/A's Avatar
Linky no worky???
Old Mar 22, 2004 | 12:11 PM
AZ Power & Sound's Avatar
Originally Posted by Smoke T/A
Linky no worky???
ditto
Old Mar 22, 2004 | 12:42 PM
Nasty N8's Avatar
It works over here.
https://ls1tech.com/forums/sponsor-sales-specials/150371-nastyperformance-aluminum-catch-can.html
Old Mar 22, 2004 | 12:44 PM
Nasty N8's Avatar
Should work now
Old Mar 22, 2004 | 12:56 PM
Zero2Sixty's Avatar
This should help :
Old Mar 22, 2004 | 01:00 PM
Nasty N8's Avatar
Thanks Man
Old Mar 22, 2004 | 02:55 PM
black_z's Avatar
Looks good, Ill be ordering one shortly. I just got an underage consumption ticket.
Old Mar 22, 2004 | 03:41 PM
Nasty N8's Avatar
Ouch thats no good. Bad boy.
Nate
Old Mar 22, 2004 | 08:40 PM
Country Boy's Avatar
Senior Member
How is that going to work? Theres only one inlet. We arent using over flow tanks
Old Mar 22, 2004 | 09:23 PM
Nasty N8's Avatar
There is 2 one on top one on the bottom.
Nate
Old Mar 22, 2004 | 11:20 PM
Mike K.'s Avatar
cool If I need one I'll make sure and look you up.
Old Mar 23, 2004 | 04:02 AM
67pete's Avatar
Drain?
Old Mar 23, 2004 | 07:09 AM
DARK AGE 53's Avatar
Nate, I see in your post over at the Sponsor GP section you mention it can be used as a oil can, if you have a fitting on the top and one on the bottom I can't see it being used for an oil catch can. JMO
Al
Old Mar 23, 2004 | 08:12 AM
Senior Member
Al
Thats what I was getting at Thats just a over flow catch can with one inlet and the drain at the bottom. It wouldnt work for what we need them for.
Old Mar 23, 2004 | 10:06 AM
TransAm00's Avatar
accurate performance catch can is much more detailed
Old Mar 23, 2004 | 12:21 PM
FinalTA's Avatar
Wouldn't you need the two fittings at the top of the can?
Old Mar 23, 2004 | 12:26 PM
67pete's Avatar
I would think you would have the input hose connected toward the bottom and the output toward the top as gravity should pull the oil down to the bottom of the can, away from the intake port, and at the very bottom there would be a drain tap(if accessable).
Old Mar 24, 2004 | 09:01 AM
BlackHawk131's Avatar
Restricted User
I am wondering why ol Nate is not giving more detail. WHAT IS THIS THING AND HOW DO YOU EXPECT IT TO WORK????? This looks like a small muffler. Please Nate, go into some detail on your product. I can tell that it is not billet aluminum. If you are the man that designed it, you should be able to explain how this works, I know Todd can tell you a lot about his product(AMW catch can).
Old Mar 24, 2004 | 11:58 AM
Nasty N8's Avatar
I made a simple can with 2 fittings one in one out. If it does not work for your setup I appolojize. I will see about making one with 2 fittings at the top but it will be a while I have them all polished.
Nate
