Huge issue!!!
Huge issue!!!
So last night while doing my h/c swap I accidently dropped the oil pan pick up fube bolt into the pan. I had pliers and a magnet on it and it still fell in. is there anyway you guys know to get it out of the pan? I know im that guy now. But just want to resolve it. Any help would be great. Thanks!
i had to use a flexible magnet and got lucky, after that i tied a long thread to the bolt incase i dropped it again, which i did several times but the thread made it very easy to just fish back out. once i got it started pretty good i just snipped the thread and finished tightening the bolt. good luck, it just takes alot of time and patience
Well after 40 minutes and a high powered magnet I dragged the bolt through the senor hole. Worked good. Magnet had enough power so i could drag it on the outside of the pan and up the side to the hole. I also forgot to tell you guys I got a 10mm socket dropped down there too so got them both out through the sensor hole but the socket was a tight fit. Thank god for all that lub on there!!!
