TR5 gap?
Old 03-04-2012, 05:49 PM
sepsis's Avatar
Default TR5 gap?
Hey guys, sorry for the stupid question. I searched a bit, but I didn't find a definitive answer.
What should I gap my NGK TR5's to? 40?
I just pulled my manifolds, gonna install my headers and poly mounts and I figured I'd do my plugs while there is room.
Thanks.
Old 03-04-2012, 07:32 PM
mjs1012's Avatar
IIRC the tr5's are the same as the tr55's so they should be gapped to .50 Correct me if I'm wrong
Old 03-04-2012, 08:06 PM
sepsis's Avatar
Anyone else know for sure?
Old 03-04-2012, 08:07 PM
z-maro's Avatar
They are not the same. As far as I know the tr5's come gapped at .50, and tr55's at .55 (hence the numbers after the tr). I gapped my tr55's to .60 as that what was in the owners manual, but apparently they changed the recommendation. I did a lot of searching and could not find a definite answer, just a bunch of opinions.
One thing people recommended to me is to not put the plugs in till the headers are in. That way it is easier and you don't risk breaking one when installing the headers.
Old 03-04-2012, 08:10 PM
Darkman's Avatar
The current specification (both GM and NGK) is 0.040"- it has varied from time to time hence the confusion.
Old 03-04-2012, 08:16 PM
sepsis's Avatar
Cool, thanks guys.
I am NOT looking forward to doing the poly motor mounts, but with the exhaust out, it looks much easier than it probably is.
Old 03-04-2012, 11:03 PM
badfbodyz's Avatar
some people have a harder time changing the mounts than others. it took me a little over an hour to do both sides on mine with the exhaust off
Old 03-05-2012, 01:02 AM
omarrakeen's Avatar
ive heard that tr5 and 55 are gapped the same but am sure its as z-camaro said...ive ran tr6 out of the box on a bolt ons car but now going with tr55..
Old 03-05-2012, 09:11 AM
moeZ28's Avatar
TR5's and TR55's are the same plug out of the box except the gap. TR5's are gapped .035" out of the box and TR55's are gapped .055" out of the box. You should be gapped .055" on an N/A application.
Old 03-05-2012, 03:02 PM
The Scammer Hammer
dr_whigham's Avatar
When I did my headers in November I put new TR55's on and they were pre gapped at .055, which is what I read to have them at for N/A, so I left them at that.
Haven't had any issues.
Old 03-06-2012, 11:03 AM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Holy **** the misinformation is rampant around here! The numerical designation on the plug is the HEAT RANGE not the ******* "gap out of the box".
Here learn something:
http://www.ngksparkplugs.com/tech_su...lugs/index.asp
http://www.sparkplugs.com/sparkplug4...-Bosch)&mfid=0
The dumbshittery around here is amazing somedays.
Old 03-06-2012, 04:02 PM
z-maro's Avatar
https://ls1tech.com/forums/generatio...r55-plugs.html
Last couple posts:http://www.ls1gto.com/forums/showthread.php?t=243764
http://forums.corvetteforum.com/c5-t...same-plug.html
And from NGK themselves, check out the bottom chart on the last page.http://www.ngksparkplugs.com/docs/te...bols_plugs.pdf
Here is a pic to make it easier:
Not to be a dick, but all the insults were not really needed.
Old 03-06-2012, 05:29 PM
Talking
That is all well and good, if not the dumbest spark plug anomaly known to man. I can't believe NGK would waste money on a plug gap designation. If you check the listed TR series of plugs this is the only one you'll find with the TRX"5" designation. I am flabbergasted by the retardation of this revelation.
Hat tip to you!
Sadly I just ordered a set of TR55s and TR6s from RockAuto.com when I could have just ordered the TR5s out of principle.
I stand by my statement that the majority of people here don't know their *** from their elbow when it comes to "tech" and spread some of the most unimaginable crap around. Present company excluded.
Old 03-06-2012, 07:18 PM
moeZ28's Avatar
Open a box and check them...they will come out as most of us have said on here. I just did it a couple months ago with my silverado, and have done it alot with my old car and about to with my new one. everytime, tr55's were 55 out of the box, and tr5's have on two occasions, been 35...NO TO BE A DICK either.
Old 03-06-2012, 07:21 PM
moeZ28's Avatar
Dont worry guys, he is from Canada...its normal to act like a cocksucking ****** ******** there!
Quick Reply: TR5 gap?
