-AN fitting question
I am using summit racing 6an steel braided lines on my transmission cooler set up. I assembled the lines and fluid cooler to flush the system. I used kooler kleen. during the flush, the fittings became frosty cold (expeected). The 90 degree swivel ends started to seep fluid. Is that to be expected when the fittings gets that cold? The summit racing tech guy said to use the fittings because he did not think that would be an issue. I like second and even third opinions. Here is a pic of where it leaked. The swivel end is designed to move when the hose is assembled. Only the swivel ends leaked. All of the straight hose ends did not because they use compression to stay sealed.
