Yet another LM7 build
Old 03-10-2012, 09:47 PM
Datankid069's Avatar
Default Yet another LM7 build
Well guys and girls winter is now behind us and santa has come and gone. I figured what better time to start tearing into my christmas present from the wife a used LM7 long block. After seeing the motor I thought what a great opportunity for a budget swap, always wanted to do one with a 5.3 base. As I thought about it this motor is like the mystery meat they served me for chow in Iraq and Afghanistan. I had no idea what it was, where it came from, or how long it was there. So with that said looks like this is going to hopefully turn into a nice build, with some guidance from the peanut gallery (you), some friends and my drive to learn. This by the way will be the first attempt at assembling a short block.
Here's some pics
Notice the left outside bolt on the #1 main cap.
Old 03-11-2012, 07:01 AM
RezinTexas's Avatar
Are you going to do a stock rebuild? What measuring tools will you be using?
I'm in the same boat, ended up going with 4" crank and a 3.9 bore.
Good luck!
Old 03-11-2012, 11:12 AM
Def gonna be a stock bore size and stroke. I'm going to try and keep this build as cheap as I can. As for measuring tools if I can stay away from the machine shop I will, but without knowing any info about the motor I don't think thats a good idea. So if I end up going to a machine shop for cleaning I'll try see if they can take a few measurments.
Old 03-11-2012, 04:37 PM
Finally got a chance to tear into the christmas present so I wanted to give yall a look inside.
These were the rod bearings that looked to have the most wear.
Old 03-11-2012, 04:50 PM
Main bearings looked pretty good.
#3 main bearing
Not sure what that is, didn't want to touch it while taking pics.
Old 03-12-2012, 05:17 AM
ride65's Avatar
I'm doin' a l59 (lm7,same difference),for a 2002 yukon xl. my mains had the same gunk in the oil passages in your last pic. Ended up going .020 over to true up the cylinders, just had to polish the crank.
Old 03-12-2012, 10:22 AM
I see how much did machine work run you?
Old 03-13-2012, 07:17 AM
ride65's Avatar
65.00 to boil ,120.00 for the machinework, 40.00 to polish the crank and chamfer the oil pass. shop around for gasket and stuff, the prices vary,local purchase was double what I paid on the net,place I bought from was very reasonable, only thing I bought separately were the head bolts and lifters.
Old 03-13-2012, 11:32 AM
Thanks for the info man. Ill be posting some more pics today.
Old 03-13-2012, 02:21 PM
King Nothing's Avatar
Nice!!! I can't wait to get my iron 5.3
Old 03-13-2012, 09:21 PM
Dude I'm so excited to get it done. Dont even know what imma put it in.
Old 03-13-2012, 10:12 PM
Shopping around for bearings (rod, cam, & main) and i'm a little confused guys. There so many brands and sizes out there its got me thinking. Honestly I get a warm and fuzzy for Clevite bearings, Its what I chose to put in my LS1. I just really don't get why theres so many sizes out there. Do I stick with stock replacement sizes or is this something that comes after clearances are measured. I hope i'm making sense with this question. This is a learning experience.
Old 03-14-2012, 05:20 AM
RezinTexas's Avatar
You won't know until you measure. I had to buy 2 sets of main bearings, Clevite H and HX. I'm mixing and matching them where necessary to get ideal clearances.
Old 03-14-2012, 10:21 AM
omc8's Avatar
Yes prices vary greatly. I found rings for $75 most places wanted over 100 for them.
Old 03-14-2012, 10:31 AM
Alright this is what I'm talking about I most be a idiot I came up with 303 for a complete ring set on summit. Does that sound right?
Old 03-14-2012, 06:34 PM
RezinTexas's Avatar
I paid $175 for a complete Wiseco GFX ring set
Old 03-14-2012, 08:33 PM
chrisfrost's Avatar
You can get Speed-Pro flat tops for a 4.8L from Summit for $180-190 that work great in a 5.3L ,,,,,,,,,,Rockauto for rings $50-60 LS2 timing set $30 ,,,,,,,,,,Alex's parts for bearings ,,,,,King bearings rods $16 mains like $50 ,,,,,,,,,I found an Melling standard volume n pressure new oil pump at Amazon under Northern auto for $60 brand new ,,,,,,Fred beans parts brand new GM LS6 yellow valve springs for $59 ........etc
Old 03-14-2012, 10:21 PM
my iron 5.3 (5.7 when i'm done ) will go into this
why did you choose an iron block? i'll be going with boost so of course i wanted strength . . . plus i found a iron 5.3 for $100 lol
Old 03-15-2012, 01:29 AM
need I say more! Thanks for making my day.
As weird as it sounds I love the looks of a empty f-body engine bay. It makes you think about the endless options. Good luck, keep us posted. Here's how mine sits just started digging back into it yesterday, two projects at once.
Seems to like her new bottle though.
Old 03-15-2012, 08:58 AM
red SS' rock!!
Quick Reply: Yet another LM7 build
