Drag Racing Results - made the 7's
View Full Version : made the 7's
bigchief52780
03-11-2012, 02:16 PM
first run off trailer ran 7.924 @87.70 mph. backed that up with a 7.952 @86.67 mph. there is alot of room for improvement. would changing rear gears get me to 7.60s or 7.70s? what will a 150 shot of nitrous do?
SEB
03-11-2012, 04:05 PM
I would go to a 4L60! I bet you drop 4 tenths there alone with a 4000 converter
thunderstruck507
03-12-2012, 08:48 AM
What was the 60ft and what converter do you have?
bigchief52780
03-19-2012, 10:34 PM
3000 bm holeshot. i think it was like 1.83 with a .7 reaction time.
SuperSlow02
03-19-2012, 10:55 PM
What is the weight of the car? A better converter and lower rear gear would drastically improve your times. 150 hit should put you in the 6s. If your going to spray it, you'll have to take it into affect if you swapped anything. Honestly slap a kit on there and let er eat. That tall rear gear and tight converter migh do something cool on a hit. Now of you were more concerned with NA, you could step up to a 4400/5000 stall and a 3.7-4.11 gear.
GtoSpd
03-20-2012, 05:58 AM
Swapping in a 4l60 would not help him. His TH350 is lighter and has less powertrain loss, and also has a much better ratio between 1st and 2nd gears (or it maybe 2nd to 3rd, can't remember right off). If anything, a 4l60 would slow him down.
Reaction time doesn't affect your ET. What tires are you on?
Congrats on getting into the 7s!
DETROIT_AREA_00_SS
03-20-2012, 08:31 AM
FTi Stall....4200
SPOOLED UP
03-26-2012, 07:17 PM
vids...
bigchief52780
04-12-2012, 02:00 PM
switched to 3.73 and ran 7.88. i am going to try some 93 mix with 110 tonight and take all the extra stuff out the trunk. tires are 26x11.50x17. will try to get some videos.
bigchief52780
04-21-2012, 07:55 AM
new time 7.66 @ 88mph 1.714 60ft on 93/110 fuel mix
