is an adjustable fuel pressure necessary
Old 03-11-2012, 06:37 PM
NJWS6's Avatar
Default is an adjustable fuel pressure necessary
with walbro pump and 42lb injectors?
Old 03-11-2012, 08:33 PM
bayer-z28's Avatar
Depends how your fuel pressure is holding up. I'm having issues, so I had to install an FPR and re-plumb 50% of the system.
Old 03-12-2012, 11:26 AM
ZL1Killa's Avatar
a FPR is typically used if you are completely re-doing your fuel system OR adding forced induction where you are having to compensate for the pressure difference at the injector for the physical injected fuel pressure versus boost.
you could also replace the factory fuel pressure reg.
When i first did my fuel upgrades, I put in 42# injectors and the Racetronix pump kit w/harness. Prior to that, and after that installation I had no problems with fuel pressure
