How to setup a fuel pump relay??
Any good Web sites or info out there on how to setup a fuel pump real for a aero motive 11140 style pump!not sure how to wire the relay!thanks guys
I'm running a ls6 in a 68 camaro fuel injected ,going to add on a kenne bell do I'm going to need more fuel!stock wiring won't handle the job!i currently have a ricks hot rod gas tank
i just wired a second fuel pump for my trans am this weekend actually...this is a good basic diagram to go off of to give you and idea on where each wire needs to go...
and for terminal 86, i personally used a hobbs switch to turn my pump on when i hit 2 psi boost...i dont know the situation you have for a signal wire...but im sure you can use your signal wire from your pcm to turn your relay on, so itll power your pump.
10gauge for the pump neg.
10gauge for the pump pos.(to relay pin 87) through the relay and then 10gauge to the alternator charge stud (from relay pin 30)
the relay ground can be 16 or 18gauge(relay pin 85) and so can the fuel pump power wire(relay pin 86)
the 10gauge is highly recommended for the right amount of current draw for the pump to perform best.
