Western Members - Is it hard to connect gauges??
chevystyle
03-13-2012, 04:49 PM
Wanna get Oil Temperature and wide band O2. Maybe a 3rd one....but can't think of a 3rd one. Can you?? Wanna get a 3-gauge pod for the pillar.
Thanks.
MrElectric03
03-13-2012, 08:45 PM
Oil temp is not bad, youll tap into a wire off of the computer for an electrical one or install a fitting and run a tube though the firewall for a mechanical.
For a wideband youll need to weld in another oxygen sensor bung into the exhaust.
Is your car an auto? of so trans temp is good to watch
cntrmnt02ss
03-13-2012, 09:36 PM
fuel pressure, or no2 pressure are also possibilities
Ray455
03-16-2012, 12:22 PM
Not trying to thread jack, since it'd probably be good info for OP too, but anyone know the easiest place to run the senders through the firewall? Have everything hooked up, just need the senders run for a trans temp and oil pressure gauge (both electric)
allblacksrt4
03-16-2012, 12:29 PM
I usually run my stuff through the whole behind the pcm. there is a big grommet there if you pull out the pcm
ZexGX
03-16-2012, 02:29 PM
3rd one: http://www.summitracing.com/parts/ATM-3585
MrElectric03
03-16-2012, 07:21 PM
ditto
Ray455
03-17-2012, 11:38 AM
Good info, glad I didnt start hacking stuff up lol. Thanks a lot
:thumb:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
