New cam install, off by 1.25 degrees.
Installed a new cam along with stock LS2 timing chain. Dot to dot and the checked with a degree wheel, it turns out to be retarded 1.25 degrees. What will be the result if I just leave it be? I don't really want to spend any more money on and adjustable timing set, but if it's that important I guess I will.
Wow to the first response.You can just leave it,its not really a big deal.Most will leave it if its within 1.5 degrees of the cam card.If it was more than 2 degrees off than you may want to do something about it.It wont really affect much only being 1.25 off,my cam was .5 degrees off and i was suprised how close it was
