Removing rear o2's without tune?
Old 03-18-2012, 07:41 PM
Blwn_by_Twins's Avatar
Default Removing rear o2's without tune?
What will happen? I'm doing a lot of small things over the next couple of weeks and am planning on buying some form of tuning software after all is done, but I figured while I have the car in the air I'd like to pull the rear o2's and use the bungs for wideband o2's.
Old 03-18-2012, 09:04 PM
SS SLP2's Avatar
Pulling the rears will not effect the running of the auto, will throw a code unless turned off with a tune or use simolaters, you may use the hole for wideband if no cats/gutted cats.
you may buy a bung at parts supplier if you want to weld in a differant bung in front of cat ( ask for spark plug spacer for a oil burning engine )
Johnny
Old 03-18-2012, 09:32 PM
TransAmWS.6's Avatar
Your SES light will come on and you will need to delete them from the PCM, other than that you should be good to go.
Old 03-19-2012, 04:47 PM
But driving it WITHOUT turning them off threw a tune will not hurt anything, right? Just through a CEL?
Old 03-19-2012, 05:00 PM
redtan's Avatar
It won't damage anything.
