Cutting Coil Springs
Old 03-23-2004, 09:53 PM
LS1INSIDE's Avatar
Default Cutting Coil Springs
Ok, I know this is a newbie question and well I don't really want to mess up my extra set of springs but i just wanted to know what you guys mean by when you say cut 1 coil? do you all have pics of it? or do you all cut from the bottom? anyone have a write up? thanks
Old 03-25-2004, 07:08 PM
alexe56's Avatar
I cut 1 full coil from the top of the rear springs on my 02 Z28 and it lowered the rear almost 3/4". This brought the rear height even with the front of the vehicle. I used an angle grinder and constantly dipped the spring in cold water to avoid losing its temper. I thought the car looked better and I had no issues with the set-up.
Old 03-26-2004, 12:31 AM
Onyx Z's Avatar
What about the front springs?
Old 03-26-2004, 02:05 AM
LS1INSIDE's Avatar
So you cut off the top of the springs?
Old 03-26-2004, 03:25 AM
Whiteside04's Avatar
I have a 96 Trans Am and I cut 1 coil and a 1/4 all the way around.It drop it about 1".I cut the bottom all the way around.Just don't cut the small end.I don't know if 98 and up are the same ?Maybe this will help.
Old 05-11-2004, 12:16 PM
LS1INSIDE's Avatar
anyone else? what about the front springs? I'm thinking on doing this today.
Old 05-11-2004, 01:44 PM
mako22's Avatar
Just had the guys at the shop cut my fronts only - same method as mentioned above, cut from top. They cut almost a full coil, and now the car is really "jacked up"/raked. No difference in ride quality and I actually prefer the way it leans forward. I still may take a half a coil off the rear next week...sorry no pics yet.
