Regret going E85?? or not going??
It's 39 vs factory 16.8 so 22.2 gallons more than factory fbody, so roughly 165lbs more weight than a an fbody tank full. It doesn't drop the supsension that much full vs empty, not as much as you would think, it's mounted right above the rear end so the weight isn't real far back.
Edit: I should also mention four 5 gallon gas cans fit perfect in the trunk, giving me 59 gallons fuel if I really needed it for a long road trip, getting 18mpg as it does cruising on the highway will get me over a 1000 mile fuel range! If I can't find an e85 then with that range...guess I'll just give up lol.
I will be doing e 85 on my ctsv this year. There is only one place to get it around me (40 miles away) so ill just run my gas map most of the time and e 85 when i want to beat her to death
I love it! I run my TA on it, and I run my vette on it also, switching back to gasoline if I take any trips....easy just a reflash of the pcm when the tank gets down and refill.
I bought a E85 tester also.... one station here messed me all up, first trying to get my TA going on new 160# injectors.... stuff turned out to be only 30% ethanol....grrr. I recomend gettnig one they are cheap.
