Th400 swap now codes poping up
1 Post
If you don't have a speed sensor in the TH400 and/or a neutral safety switch hooked up, you are going to have all kinds of timing/rev limiter/idle issues that your tuner will have to work on... it will be running off of the park/neutral tables... PCM won't know the car is in gear or moving.
