Crank question
Old 03-25-2012, 02:08 PM
PSI GUY's Avatar
Default Crank question
I am building an L92 for my 93 Camaro and running a 2000 ecu and harness. I had previously bought an LQ4 to build but found an L92 for cheap. Instead of running the conversion box for the 24x conversion I was going to swap the gears on the cranks. Later found out that is is quite the project that involves special tools to do, so can I use the LQ4 crank in place without modification in the L92?
Old 03-25-2012, 02:54 PM
427's Avatar
The crank would need to be balanced for the L92 bobweight.
Kurt
Old 03-26-2012, 11:11 AM
1lejohn's Avatar
I'm thinking they both would need the conversion box the PCM is for a 24 tooth reluctor. What year is the LQ4?
Old 03-26-2012, 01:20 PM
TurboS10's Avatar
ERL or Katech rents the alignment tool I think.
Can't remember where I saw it.
GM sells the 24x wheel seperate.
Any machine shop can do the swap.
Old 03-26-2012, 05:06 PM
nobreaks254's Avatar
if anyone knows of a place that rents the tool, please post up! I need one asap!
Quick Reply: Crank question
