5.3 RX7 No oil pressure any thoughts?
Old 03-25-2012, 08:16 PM
bp m1009's Avatar
Default 5.3 RX7 No oil pressure any thoughts?
im building an 86 FC rx7 with a 5.3 and t56. recently primed the oiling system with a pressure bleeder but still dont get oil pressure when i run the engine, anyone have some suggestions?
Old 03-25-2012, 08:22 PM
got-a-ls1's Avatar
have you verified its not pumping oil either via a mechanical gauge or atleast by looking at the rockers and too see if the oil is coming up the pushrods?
Old 03-25-2012, 08:27 PM
bp m1009's Avatar
im going to buy a mechanical gauge but as of now the oil pressure sender is hooked up to the factory mazda gauge and doesnt read anything and i also have checked the rockers multiple times to find they are dry
Old 03-30-2012, 11:54 AM
bp m1009's Avatar
any one??
Old 03-30-2012, 02:01 PM
bluethunder364's Avatar
Could be your o ring on the pick-up tube. Many people have had this problem if not assembled correctly. I would pull the motor out and check it, or if you can drop the oil pan and front cover. I know this may not work as I have a 91 RX7 with an LQ-4
Old 03-30-2012, 02:53 PM
bp m1009's Avatar
Im almost positive i installed the o ring right i did it while the engine was upside down on an engine stand, because i knew the oring can cause so much trouble if installed wrong
Quick Reply: 5.3 RX7 No oil pressure any thoughts?
