5.3 RX7 No oil pressure any thoughts?
Could be your o ring on the pick-up tube. Many people have had this problem if not assembled correctly. I would pull the motor out and check it, or if you can drop the oil pan and front cover. I know this may not work as I have a 91 RX7 with an LQ-4
