Which gaskets with 1/2" studs
I've got a 6.0 iron block with 4.030 bore and 1/2" studs. What GM mls gaskets can i use? I have a set of gm part number 12610046 and they do not clear these studs. i have to thread each stud through the gasket and then hammer them through to the threaded portion (of the block) then go about tightening the studs. I was told this is normal, but it damn sure doesnt seem right.
