Nothing on my supercharger pulleys line up
Well i dont even know where to start but i bought a j bracket and a d1sc from different members on here and i am trying to bolt everything together but nothing lines up. i was told both would work on a ls1 camaro. the s/c pulley hits the j bracket unless you put two shims behind it but then it hits the alternator pulley when bolted up. plus with the two shims the idler pulley doesnt line up with the crack pulley or the s/c charger pulley. i checked to make sure my stands off and spacers were correct which they were. it seems like the j bracket is to thick and i need the stand offs and spacers to be 1/4 to a 1/2 inch longer. any input is appreciated, thanks
You don't need the pulley shims when you run the 6-rib pulley. Also, the 6-rib pulley has a slight offset to it. Make sure you install it so that the drive portion of the pulley sits closer to the blower. Make sure you also don't have the 8-rib idler shaft vs the 6-rib.
The 6-rib idler shaft has a base (larger round part) that's about .975" and the portion that sticks out from the bracket will be about 1.1".
The 8-rib idler shaft has a base (larger round part) that's about 1.5" and the portion that sticks out from the bracket will be about 1.4".
The 6-rib idler is 2.3" diameter.
The 8-rib idler is 2.5" diameter.
