t56 clutch setup in 88 fox
im attempting to get my parts ordered for my fox but am unsure where to mount anything or what other parts i need.
i liked the GM part in post 5 from this thread-https://ls1tech.com/forums/conversio...-cylinder.html, but would like some more direction for my particular application.
I fabbed my mount, I used the Wilwood 3/4 clutch master
I painted the pedal before final install, this set up gave me the correct throw. Cant remember if it 1 or 1 1/4 inches of throw.
Last edited by zipster; 04-07-2012 at 09:03 AM. Reason: had wrong size of master cylinder bore
wow that's pretty straight forward.
i like that, i saw another thread a couple mins ago that required a lot of fabrication to the entire pedal assembly but this looks like its pretty simple. thanks i will probably steal your idea if you don't mind
