moneys tight need some help!!
Old 04-07-2012, 12:15 PM
Brewski4u1's Avatar
Default moneys tight need some help!!
Ok so the bearing went bad on the drivers rear and took out the axle. well i need another axle. i know all the 99-02 z28 m6 are the same but what other axle or models will work going to the junk yard in a few days see if i can find a good one .
thanks
Old 04-07-2012, 02:49 PM
01ssreda4's Avatar
Auto axles will work as well.
Old 04-07-2012, 02:54 PM
BTLD_LS1's Avatar
u in San Antonio by any chance?
Old 04-07-2012, 03:39 PM
SparkyJJO's Avatar
Any 98-02 fbody axle will work. V6 or V8, Camaro or Firebird, auto or manual, doesn't matter, the 10 bolt axles are all the same. The only difference is the ABS system - 4 channel ABS cars have reluctor rings on the axles, 3 channel ABS cars don't. I believe the reluctor ring can be removed however.
Old 04-08-2012, 02:47 PM
Pocket's Avatar
The ring can be pressed off the 4 channel axles, but 3 channel axles do not have the machined surface cast into them, so theres nothing to press the ring onto
