moneys tight need some help!!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ok so the bearing went bad on the drivers rear and took out the axle. well i need another axle. i know all the 99-02 z28 m6 are the same but what other axle or models will work going to the junk yard in a few days see if i can find a good one .
thanks
thanks
Any 98-02 fbody axle will work. V6 or V8, Camaro or Firebird, auto or manual, doesn't matter, the 10 bolt axles are all the same. The only difference is the ABS system - 4 channel ABS cars have reluctor rings on the axles, 3 channel ABS cars don't. I believe the reluctor ring can be removed however.
