PCM Diagnostics & Tuning - Big tire=no abs/asr!?!?!
MIG74
04-08-2012, 10:16 PM
Hey guys, anyone figure out how to make the abs/asr work after mounting 295/45/17 Mickey dr's? Tires measure @ 27.2. I have EFI live but the ebtcm is controliing the vss(?)I believe. I've tried searching and have come up empty aside from people removing bulbs (no thanks). Any help will be greatly appreciated.
98Camarod
04-09-2012, 05:17 AM
You can get rid of the lights by jumping a wire across on the abs wiring harness and running a ground wire IIRC. I'll search and see if I can find that thread. I did it a while back and it worked. I don't have that harness any more or I'd check.
98Camarod
04-09-2012, 05:37 AM
Found it, but apparently it's only for 98 cars:
http://ls1tech.com/forums/drag-racing-tech/614651-found-cure-cluster-lights-after-abs-delete.html
BOBS99SS
04-09-2012, 05:53 AM
just pull the abs light out lol, issue solved, or ditch the abs which is what most do,
MIG74
04-09-2012, 07:55 AM
Thanks for the input guys. Interesting read on the 98 only cars. I plan on replacing the 10 bolt, hopefully before it breaks, and then I will remove the abs and add a propotioning valve and a line-lock, I guess. Damn.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
