408ci build, expectations/suggestion.......
Have a friend putting together a 408 LQ4, we r wondering what everyone thinks it will put down, anyone have any tips or suggestions on the build itself?
Details: 408LQ4 Mahle -12cc dish pistons (.020 above deck), 10.9:1 SCR,
PRC Stg 2.5 Ls6 heads, 64cc chambers .660 dual springs,
kooks 1.75" LTs,
TSP True Duals,
Catless, 42lb green top SVO injectors
gm mls headgasket
K1 6.125 rods
K1 4" crank
242/246 .612 .614 113 + 2
Ls7 Lifters
Tsp Oil pump
Asp 25% UD
Monster Stg 3 Clutch and flywheel kit
moser 12bolt 4:10s
Fast 90/90
Volant Twin cone Fbody CAI
85mm Maf
Steel DS
Car is a 2001 M6 WS6, will be dynoed on a dynojet 248h. Dyno is a bit tough, G6x3 cam, 1.875" Kooks, o/r xpipe, Ud pulley, fast 102, cold air induction CAI, M6 2010 LS3 Camaro put down 483/445wtq on same dyno.
Hes hoping for 525ish whp/490wtq
Other cars that have dynoed @ the same shop:
WWW.DYNOSPORT.COM
kooks 1.75" LTs,
TSP True Duals,
gm mls headgasket
K1 6.125 rods
K1 4" crank
Ls7 Lifters
Tsp Oil pump
Asp 25% UD
moser 12bolt 4:10s
Fast 90/90
85mm Maf
Steel DS
WWW.DYNOSPORT.COM
Looks pretty good, personally I ditched my MAF in favor for an SD tune, and went with a 255/263 .634/.624 115lsa cam. You would be suprised st how much duration the larger cubes eat up and tame down.
I'm gonna guess 480-490hp. That's not quite enough cam/compression/heads to reach 525rwhp IMO. But hey, I could be wrong.
Also, there's a whole section dedicated to dyno guessing and bench racing
https://ls1tech.com/forums/dyno-gues...ing-forum-150/
Kinda looking for more than just guesses here, really appreciate others feed back on what the weak parts of the build are.
Still wanting a streetable car so didnt go bat **** crazy with it. Figured the cam posted with a little larger LSA, but appreciate the suggestions!
kooks 1.75" LTs,
TSP True Duals,
gm mls headgasket
K1 6.125 rods
K1 4" crank
Ls7 Lifters
Tsp Oil pump
Asp 25% UD
moser 12bolt 4:10s
Fast 90/90
85mm Maf
Steel DS
WWW.DYNOSPORT.COM
kooks 1.75" LTs,
TSP True Duals,
gm mls headgasket
K1 6.125 rods
K1 4" crank
Ls7 Lifters
Tsp Oil pump
Asp 25% UD
moser 12bolt 4:10s
Fast 90/90
85mm Maf
Steel DS
WWW.DYNOSPORT.COM
With the 12cc dish mahle and 64cc heads I think we are hard pressed to get to the 11.5:1 and higher SCR. Heck the pistons are already around :020 to :025 above deck! Tried talking him into going with the 8cc dish pistons from weisco but he didnt want to spend the extra 125-150 bucks for them. Should be around 10.9:1 SCR
Well the heads were to get milled down farther, I think it would be losing some Flow for Compression. Another thing is how much PTV we would still have. It should have enough room with the dished pistons but Im sure we would want to check first.
Im guessing a upgraded set of PRC Stg 3 LS6 heads slightly milled and a little bigger stick (246/253 .62x .62x 112LSA) would be a nice upgrade for him down the road. would be nice to convince him to go with a set of TFS or AFR's!!
Take it with a grain of salt, this is the internet. I think it looks like a strong combination of parts for the money invested......however, I would ditch the (I presume) stock steel DS in favor of an aftermarket unit, and like already stated consider a SD tune. 1 7/8 th headers may benefit some on this combo as well. We are just trying to help you. If you want semi-exact numbers, nobody can give them to you, but some digging on your part may yield some numbers on some very similar combos.
I understand this is the interwebs just seeing if everyones on the same page so r expectations arent too high, and some insight on the areas we have to improve on.
