Generation IV Internal Engine - Nice cam from Pat G
View Full Version : Nice cam from Pat G
backchannel
04-12-2012, 10:58 AM
08Z06
run 69 is 32* overlap cam, Marcella intake
run 72 is same cam , Hogan crossram with small runners
run 79 is Pat spec 22* overlap cam with new Hogan intake
driveability is very nice with the new cam and pleased that power is increased all the way to 6300 where the bigger cam finally equals.
I will certainly use Pat to spec any cams for new builds :drive:
blackonblacksls
04-12-2012, 11:40 AM
Pics of the intake Setups?
backchannel
04-12-2012, 01:35 PM
tried to attach but fails-maybe I'll try to load from elsewhere
blackonblacksls
04-12-2012, 03:26 PM
or send them to me, and ill post them..
drpena13@gmail.com
backchannel
04-12-2012, 03:49 PM
drpena13@gmail.com
sent pic of last Hogan-thanks
blackonblacksls
04-12-2012, 03:56 PM
http://i104.photobucket.com/albums/m199/blackonblacksls/camaro%20pics/IMG_0045.jpg
blackonblacksls
looks pretty badass
blackonblacksls
04-12-2012, 04:03 PM
http://i104.photobucket.com/albums/m199/blackonblacksls/camaro%20pics/IMG_0018.jpg
http://i104.photobucket.com/albums/m199/blackonblacksls/camaro%20pics/IMG_0019.jpg
Tainted
04-12-2012, 04:16 PM
Thats a pretty serious intake!
+1 for another great Pat G cam!!!
blackonblacksls
04-13-2012, 04:18 PM
what you do with all the other intakes?
studderin
04-13-2012, 08:32 PM
so 3 cams with 3 different intakes. Have 3 different power outputs.hummm
ramairws6
04-13-2012, 10:18 PM
?? That's what i was thinkin'??:eyes:
backchannel
04-14-2012, 09:32 AM
Huh! Where do u see 3 cams? The progression should be obvious-looking to keep power but improve driveability. First manifold was not re-dynoed after cam change because I already knew it had too short of intake runners for my goal, second manifold was too small.
blackonblacksls
04-14-2012, 12:13 PM
care to share some cam specs?
maybe through pm if needed?
I just got my ls7 motor on the dyno and was surprised how early it peaked.. Also looking at yours even the highest revving cams don't pull past 7k.
backchannel
04-14-2012, 03:13 PM
Sent some basic info but it would be best to give Pat your details and get a cam spec'd that optimizes your combo. I should have done that earlier. :cheers:
