Conversions & Hybrids - aftermarket wire harness
View Full Version : aftermarket wire harness
turbobowtie
04-15-2012, 03:17 AM
who has the best deal on an already made or aftermarket wire harness for 5.3 with a 4l60e trans ?? thanks in advance .
LS1MCSS
04-15-2012, 05:04 AM
PSI http://psiconversion.com/
2nd Gen Fl 'bird
04-16-2012, 08:57 AM
This^^^^^^ hands down.
68BBChevelle
04-16-2012, 12:24 PM
x50!!!!!
camarochevy1970
04-16-2012, 02:40 PM
am I reading that correct, $499 for a harness already modified for a swap?
tta656
04-16-2012, 04:07 PM
there are about a dozen places cheaper and seem to do good work,$499 doesnt make my swap a budget swap any more,,im going cheap
99VetteFRC
04-16-2012, 06:51 PM
Cost me only about $40 to rewire my harness myself. $15 of that was a 6 curcuit fuse panel from Auto Zone. Some heatshrink and solder and some electrical connectors. That was it. I am actually doing a second harness cuz I took all the trans connectors out of my first harness.
Old_Yeller
04-16-2012, 08:41 PM
PSI has a nice harness. I don't have any experience with any other harness, but this one was easy to use and was clean.
Xtremes10
04-16-2012, 08:43 PM
I used a Current Performance harness... it was plug and play into my fuse block, a little bit more but its top notch and completely clean and application specific...
2nd Gen Fl 'bird
04-17-2012, 08:38 AM
The harness is new from one end to the other. That's why I went with PSI. You can modify a stock harness and I would feel better about doing that if I knew it came out of a running car. The story of "I got to dig it out, it's in a box somewhere in my garage", not here. People with the knowledge to track bad connectors and grounds and the such to make stuff work have my respect.
