862 Head Gasket Options?
What head gaskets are you guys running with 862's and boost? I understand I can't run GM MLS gaskets, and that Victor Reinz makes one that's supposed to work with notched heads, but I can't see where anyone uses them. Will the Victor Reinz gaskets live under boost? Will composite gaskets live under boost? I am running ARP bolts.
1 Post
Ran in to same problem but picked up a set of 241, on the 862's there a only a small notch.I personally would get them weld in then mill the heads, On the other hand people have been boosting engines for years before mls gaskets, you dont know till you try lol.
