Generation IV Internal Engine - Brand new engine..builds maybe 10psi at 2krpm then 0 at idle..
Snyper
04-19-2012, 09:45 PM
So I fired my engine for the first time tonight and the car built maybe 15psi of pressure at 2k and when the revs came back down the pressure drops to 0. Gauge works correctly(verified)..the lifters are getting no oil whatsoever neither is the top end of the engine. Possible causes?
Im running a Mellings hi volume pump with the spring that came with it installed(hi pressure hi volume). I let the car idle for about 30 seconds twice..and it was so bad the car started to backfire violently(guessing its because the valves are barely opening)
XtraCajunCTS-V
04-19-2012, 09:55 PM
Do you have the oil galley plug (dumb bell) installed in the rear of the block or the plug installed in the front next to the oil pump on the driver side?
Thanks,
Shane
Snyper
04-19-2012, 09:56 PM
ERL did the block. The plug is in the front. Im not sure about the rear...but im guessing they wouldn't forget to put those in.
bwkmaro
04-19-2012, 10:51 PM
sounds like plugs are missing from the block and its leaking out. my machine shop guy forgot them too not to far fetched
djjonesivs
check the oil pump.
the valve train usually gets the oiling first.
if its not getting any oil up their then its possible it may be a pump issue.
Snyper
04-19-2012, 10:55 PM
When turning the engine over with the rear oil sender out oil seeps out of there slowly. One thing I didn't do was soak the lifters but it still should of had something after running for 30 seconds. The car was popping and BAD. ALl the rockers look almost level (no oil in lifters)
00byrd
04-20-2012, 02:39 AM
check the o-ring at the pickup tube and make sure it didnt get cut or pinched. gl
XtraCajunCTS-V
04-20-2012, 07:34 AM
Sounds like the rear oil galley plug was left out... It happens all the time.
Snyper
04-20-2012, 10:53 AM
Removed the plug above the filter looked in there and saw no plug. >:(
Jimbo1367
04-20-2012, 05:57 PM
I think you should let it run some more first! Personally. if I couldn'y get ANY oil from the rockers during prelubing, I wouldn't attemp to start it.
I DO hope you primed your engine first. I would hate to think of the damage to EVERYTHING. Best of luck bro
Snyper
04-20-2012, 06:10 PM
Put the plug in the hole and the pressure shot right to 60psi. It took about 45 seconds for oil to start coming out of the rockers but there's oil. The car also sounds like is has the 262/266 cam that I put in instead of a stock can. Let's just hope there's no damage.
70shortwide
04-21-2012, 06:58 PM
what is this rear plug you talking about? i tried to prime motor today and it wouldn't build any pressure at all.
Snyper
04-21-2012, 09:26 PM
Little white plug to the left of the crank from the back.
Quick Carl
04-23-2012, 11:27 AM
Check that the valley cover has seals to seal up the DOD ports also.
LS1MCSS
04-25-2012, 07:56 PM
Here is what it looks like and it installs in the back of the block. There should also be a small freeze plug type of plug in the front of the block, under the timing cover off to the right of the cam.
http://ls1tech.com/forums/attachments/generation-iii-internal-engine/20553d1104542359-correct-part-number-rear-plastic-plug-ls1plug.jpg
