Street Racing & Kill Stories - 458 vs Agera R
View Full Version : 458 vs Agera R
NOLAG05
04-24-2012, 01:13 PM
To 41863nj:
Since you talked it up and i didn't want to take over that other thread any more...lol. I found the vid and thought i would post it here for ya... Enjoy
Ferrari 458 Italia vs Agera R!
http://youtu.be/_0wYrhWxmPg
ZGLASS
04-24-2012, 01:16 PM
Holy shit!
GotHemi?
04-24-2012, 02:13 PM
Ive seen this video before and its still mind boggling how fast that car is...
LS1rob00
04-24-2012, 03:34 PM
HOLY FUCK! That thing is stupid fast...
NOLAG05
04-24-2012, 04:57 PM
He cheated in that race also by brake boosting...lol. Price on the 2012 R model i think is around 1.6 and something like 4-6 months build time.
Here is the FULL rundown on her...
Technical Specifications AGERA R
Performance
Power output: 1115 hp at 6900 rpm - redline @ 7250 rpm
Torque: over 1000 Nm from 2700 to 6170 rpm
Max torque: 1200 Nm at 4100 rpm
Acceleration: 0-100 km/h (0-62 mph) 2.9 seconds
0-200 km/h 7,5 sec, 0-200-0 km/h 12.7 sec
Braking distance: 30.5m (100-0 km/h)
Lateral g-force: 1.6 g
Fuel consumption: Highway travel: 12,5 l/100km, Combined: 14,7/100km
Weight-to-power ratio: 1.19 kg/hp (dry weight)
Weight distribution: 45% front, 55% rear
Emission levels: Euro V and lev 2
Aerodynamics
Cd. 0,33 to 0,37 with adaptable rear wings.
Frontal Area: 1.873 m2
Total Downforce at 250 km/h: 300 kg
Flat underside of chassis. Venturi tunnels at rear of chassis/body.
Dimensions
Total length: 4293 mm (169")
Total width: 1996 mm (78.6")
Total height: 1120 mm (44.1")
Ground clearance: Rear: 100 mm (3.94") Front: 100 mm (3.94")
Wheelbase: 2662 mm.
Front track: 1700 mm. Rear track: 1650 mm.
Front overhang: 885mm Rear overhang: 752mm
Fuel capacity: 80 litres
Luggage compartment: 120 litres (31.7 US gallons)
Dry weight: 1330 kg
Curb weight 1435 kg (all fluids plus 50% fuel)
Maximum laden weight: 1650 kg (full tank, two passengers, full luggage)
Chassis
Carbon fibre with aluminium honeycomb and integrated fuel tanks for optimal weight distribution and safety.
Monocoque torsional rigidity: 65,000 Nm/degree.
Weight including tanks: 70 kg.
Front and rear suspension: Double wishbones, two-way adjustable VPS gas-hydraulic shock absorbers, pushrod operated.
Triplex damper in the rear.
Electronically adjustable ride height. Front: Cro-Mo subframe, with integrated crash members.
Rear: Semi-stressed engine and gearbox with support struts, for needle bearings and o-ringed wishbone bushings optimal rigidity and no engine inertia movements.
Fully machined aircraft aluminium uprights, with SKF LeMans specification 150mm angle contact ball bearings.
GKN hollow/gun-drilled driveshafts.
Koenigsegg Z-style progressive and lightweight anti-roll bars front and rear.
Engine
Koenigsegg aluminum 5,0L V8, 4 valves per cylinder, double overheadcamshafts
Compression: 9.0:1
Bore: 91.7 mm Stroke: 95.25 mm
Sequential, multipoint fuel injection.
Twin turbo superchargers
1.4 bar boost pressure.
Dry sump lubrication.
Carbon fibre intake manifold with optimised intake tracts.
Tig-welded ceramic coated inconel exhaust system manifold with merge collector.
Weight: 197 kg
Transmission
Specially developed 7-speed dual clutch, 1 input shaft transmission with paddle-shift.
Electronic differential
Steering
Rack and pinion power assisted steering. 2.7 turns lock-to-lock.
Turning circle: 11 metres. TRW electro-hydraulic power-assisted.
Brakes
Front brakes: Ventilated ceramic discs Ø 397 mm, 40 mm wide.
6-piston calipers. Power-assisted.
Rear brakes: Ventilated ceramic discs Ø 380 mm, 34 mm wide.
4-piston callipers. Power-assisted.
Traction Control
F1-style for optimal performance with 5 different handling modes.
Wheels
Koenigsegg forged Vortex generating aluminium wheels with centre locking
Front: 19" x 9.5"
Rear: 20" x 12.5"
Tyres
Dedicated Michelin Supersport
Unidirectional with asymmetric thread pattern
Front: 265/35 - 19" (Y)
Rear: 345/30 - 20" (Y)
Speed rating: 420+ km/h
Body
Two-door, two seater with removable hardtop stowable under the front hood lid. Body made from pre-impregnated carbon fibre/kevlar and lightweight sandwich reinforcements. Carbon vents over wheels.
Electrical System
Solid state digital semiconductors - no fuses or relays. Can bus operated and fully programmable functionality.
Equipment
Dual airbags, detachable storable hardtop with glass roof, power windows, adaptive rear wing, adjustable pedals and steering column, Agera stitching, adjustable seats in rake and length, carbon ceramic brakes with Sport ABS, hydraulic lifting system, power steering, power brakes, extra 4 point seatbelts for track use. satnav, Intelligent LifePo4 battery, MP3 player, USB connection, climate control, digital warning and info system, G sensor, alarm, tyre monitoring system, silver key, leather carpets, roof storage bag, car cover.
Extra Equipment
Fitted luggage, special leather and colour requests, full visible carbon body, Inconel exhaust system, Front winglets, rear view camera, heated seats, ski box roof, skis, winter wheel package, 4 point racing harnesses.
3 Year Warranty
41863nj
04-25-2012, 02:57 AM
hahahahaha...i forgot all about that...old age...hahahah...yeah that is what i was talking about...every damn time i try posting a video, nothing happens...this one and the one with the AMS ALPHA 9 GTR raping a 500+++ hp mustang cobra...pure rape...there's also one on the new aventador lp700-4 vs porsche 911gt2 rs and a amg benz...the porsche and amg got murdered...i'll keep trying to post them, i have so many in my youtube account...thanks NOLAG05 for keeping me straight lolololol...that AGERA-R was said to do 0-200mph in 17.68 sec...i love exotics and knowing i'll never be able to afford one...lololol..
41863nj
04-25-2012, 03:01 AM
damn NOLAG05...KOENIGSEGG should hire you as a spec expert...lolol...well guys, at least now we know who to go to for a car's complete break down...lololol....great job man...wow.
NOLAG05
04-25-2012, 09:31 AM
The joy of being from Detroit...lol. Been to car shows around the world and workin for Uncle Sam helps...lol. I keep up with cars that my wife would kill me if i brought home...lol. I was tryin to work out a deal for CCXr but i haven't heard from the dude in months. Would give up all my toys for a Koenigsegg!! including the wife...lol... just jokin honey...smh
whytryz28
04-25-2012, 09:53 AM
He put track lengths on the poor Ferrari.
41863nj
04-25-2012, 07:06 PM
WHYTRYZ28...lololol...yeah like train lengths...
NOLAG05...i nominate you for KOENIGSEGG saleman of the month and VP of operations, customer service rep as well..lolololol....on the other hand my wife would love for me to bring any performance car home....she can't get enough of them...she's a muscle car junkie like me...she knows her cars and will not drive anything else...but she still has a personnel fondness for a low mile second-gen firebird...maybe a 1973 SD-455 trans-am...she loves the older ones as well...
NOLAG05
04-26-2012, 08:40 AM
Since we are pregnant with our first she is quite happy in her Lincoln MKX... I told her i would get rid of it and get a 2012 CTS-V wagon... She test drove it and loves it! I would love the Agera R but am very happy with my current roster of toys... fully built 2005 STi, 64 Stingray all original, Nissan R33 & R34(having troubling it stateside legally...lol)... and a few others. I would give them all up except the Vette for an Agera!
41863nj
04-27-2012, 02:29 AM
NOLAG05...have you ever thought about adopting an older child like me..lolololol....awesome collection you have...right now i'm trying to build one of my cars for pinks all-out next year...my '87 formula now weighs about 2900lbs...if i win, cool if not will go to charity...hopefully something like kid's with cancer...
props to her liking that CTS-V wagon...awesome...years ago i found a '67 stingray , red & black w/stripe..trips..solid cam...side pipes...all original...stock..this was at cherry hill car classics...put $ 5000 down...went back with the rest to pick it and he sold it to someone else that offered more then he was asking....always wanted a stingray...yours sounds great...post some pictures at some point.
41863nj
04-27-2012, 02:32 AM
if you ever get that AGERA-R...i claim first rights to ride shotgun...neck brace optional...lolol
PhantaZm
04-27-2012, 09:26 PM
Great vid...thx for posting it
41863nj
04-28-2012, 11:38 AM
PHANTAZM...great times for a datsun....11.3@129 is rocking.
ohioborn80
04-28-2012, 11:53 AM
WOW...That was rape.
NW-99SS
04-28-2012, 12:07 PM
Amazing video to watch. Agera R, Huayra, Veyron Grand Vitesse - the cars that litter my lottery winning dreams!
jbhotrod
04-28-2012, 12:27 PM
Thats awesome, its amazing the things that can be done today. 1115hp from a stock car that can be driven comfortably.
whytryz28
04-29-2012, 12:02 PM
That was beyond rape, like 3rd string high school football player against an NFL player, huffey bicycle against an R1, bin laden aginst Seal team 6, no chance in hell of a win.
41863nj
04-29-2012, 12:08 PM
JBHOTROD...that's what i was saying in that other thread about lambo's and UGR's...nothing against a LS1 since i own them, it's just nice to start something up stock and have that kind of power...that AGERA-R should be a 9 second car right ????....i mean it left a 11sec. car flat...i know it's very expensive, but if money wasn't an object, i would buy that car in red...but i think i would have that damn wiper removed first...lolol
NW-99SS...thanks for that mentioning of the HUAYRA...that thing is quick as shit,,,seen a video on it...damn, never knew that were that quick, and like OHIO said...''rape''...at it's finest, car wise that is...
PhantaZm
04-29-2012, 03:35 PM
Thanks! It did a 10.7 @ 140 this winter with a 2.1 60' on the bottle. I'm almost ready for that Koenigsegg
audacious nick
04-29-2012, 06:53 PM
That was puppy kicking right there.
41863nj
04-30-2012, 02:16 AM
PHANTAZM...i would love to see the look on the face of a new porsche 911 turbo-S driver when he can't beat you..lololol..same times, except he traps about 130 to your 140...people don't give the old datsun any credit....not sure what that AGERA-R runs...but it sure put a butt whippin' on that 458 and again, that's a 11.00 second car....DAMN...lolol
Arctic
04-30-2012, 04:20 AM
:usa:
http://www.youtube.com/watch?v=4Y8ZsMJ5bLU
NOLAG05
04-30-2012, 07:06 AM
That honda crushed that Vette off the tree...lol.
