Gears & Axles - 96 ss u-joint part number?
98WS6WV
04-26-2012, 07:46 PM
Hey all
anyone have a part number for the ujoints on a 96 ss with the aluminum drive shaft?parts stores all coming up empty..all the ujoints there are too big.
thanks in advance!
01ssreda4
04-26-2012, 08:28 PM
LT cars have the same shaft as the LS cars. I like the Precision 234.
98WS6WV
04-26-2012, 09:15 PM
The 234s are too big.the joints don't match the parts store listings.they are factory and have spicer stamped on them.maybe they are Slp parts???
01ssreda4
04-27-2012, 04:45 AM
SLP never did u joint stuff. What was too big on the 234? What is the diminision of the joint currently on the car? What DS/yoke/rear is in the car? Help us help you.
98WS6WV
04-27-2012, 05:46 AM
OK its the factory 10 bolt.the end caps are to large of a diameter plus the body of the 234 is too wide.I thought the 96 ss cars had a different shaft.the 1 le maybe? None of the ujoints at the parts store are small enough.the drive shaft has a GM part number on it however the ujoints are just marked Spicer.this shaft has never been out of the car so i know its the original.thanks
Tom
01ssreda4
04-27-2012, 04:47 PM
How do you know they won't fit the yoke on the rear end? Have you physically tried to put one in there? The 234 WILL fit a stock 10 bolt. Can you post pics of the actual parts so we can see if they are actually stock.
FirstYrLS1Z
04-27-2012, 04:55 PM
GM parts layout catalog shows a GM#12471502
Its a GM 3R series joint.
98WS6WV
04-29-2012, 10:50 AM
OK drive shaft part number is 10085375 comes up GM 1le..the ujoints are stamped spicer p9 but I can't find a crossover.all ujoints at 4 parts stores are too big.don't really wanna buy a new shaft cause I can't find ujoints.lol
98WS6WV
04-29-2012, 11:40 AM
I'm thinking that it may be a spicer 1330 through measurements...any thoughts?
[GM 3R Series joint.
Check it out here GM3R (http://www.dennysdriveshaft.com/c135_gm_3r_series...inside..._2_916_x_2_916_inches .html)
Your driveline and ujoints are not special. you just have uninformed people wprking the parts counter,
98WS6WV
04-29-2012, 05:55 PM
OK got a correction the rear u joint is a different part number.its wider across where it months to the rear end.the front one is the same width across both directions. Maybe the front is a 1330 and the rear is a 1330/1350.
98WS6WV
04-30-2012, 06:27 PM
Well found them front was a 1310 spicer and the rear was a 1310/1330.thanks to all who tried to help.
01ssreda4
05-01-2012, 03:48 AM
Take a pic of the rear end yoke if you don't mind, DS too.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
