96 ss u-joint part number?
Hey all
anyone have a part number for the ujoints on a 96 ss with the aluminum drive shaft?parts stores all coming up empty..all the ujoints there are too big.
thanks in advance!
thanks in advance!
The 234s are too big.the joints don't match the parts store listings.they are factory and have spicer stamped on them.maybe they are Slp parts???
SLP never did u joint stuff. What was too big on the 234? What is the diminision of the joint currently on the car? What DS/yoke/rear is in the car? Help us help you.
OK its the factory 10 bolt.the end caps are to large of a diameter plus the body of the 234 is too wide.I thought the 96 ss cars had a different shaft.the 1 le maybe? None of the ujoints at the parts store are small enough.the drive shaft has a GM part number on it however the ujoints are just marked Spicer.this shaft has never been out of the car so i know its the original.thanks
Tom
Tom
How do you know they won't fit the yoke on the rear end? Have you physically tried to put one in there? The 234 WILL fit a stock 10 bolt. Can you post pics of the actual parts so we can see if they are actually stock.
OK drive shaft part number is 10085375 comes up GM 1le..the ujoints are stamped spicer p9 but I can't find a crossover.all ujoints at 4 parts stores are too big.don't really wanna buy a new shaft cause I can't find ujoints.lol
OK got a correction the rear u joint is a different part number.its wider across where it months to the rear end.the front one is the same width across both directions. Maybe the front is a 1330 and the rear is a 1330/1350.
