Generation IV Internal Engine - oil weight question
Double J
04-28-2012, 10:22 PM
Best oil for LS3 418 Stroker, big cam, high compression?? 30W, 40W or 5OW. I live in Florida, if that makes a difference as far as temps.
THANKS IN ADVANCE
427 zeo6
04-28-2012, 11:59 PM
Your oil choice is going to be affected by your bearing clearances and oil system. What are your figures? Stock clearances would stay with 10/30 or 10/40WT oil.
fastazzls1
04-29-2012, 12:25 AM
agree clearances are the main factor do you have a build sheet
of what the lower end clearances are
Double J
04-29-2012, 11:47 AM
The motor was completed several months ago and the engine builders-Arvil &Chris Fowler of XTREME HP in Texas are out of business. They never sent the build sheet.
Double J
04-29-2012, 11:53 AM
The motor was completed several months ago and the engine builders-Arvil &Chris Fowler of XTREME HP in Texas are out of business. They never sent the build sheet. What I was trying to say before server failed, they recommended 10W30 Mobil 1 syn , but my sources tell me syn not good for break in motor. I don't know if they used break in oil then changed to Mobil 1. I going to put Brad Penn Racing oil in ASAP. But I can't get in touch with them to confirm.(another story)
fastazzls1
04-29-2012, 11:43 PM
i would think i would follow what the engine builders recommend i mean gm breaks all there engines in with mobil 1 they are factory filled with it but when it comes down to it its your choice i have used pennzoil forever and never had a problem with it
bww3588
04-30-2012, 12:10 AM
If you have stock clearances, stick with 5w30 that they are supposed to Be ran on.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
