LT1-LT4 Modifications - 7730 run a LT1?
fuzzyjk
04-29-2012, 08:15 AM
I purchased a complete LT1 supercharger kit. It came with a preprogramed ECU for the supercharger and larger injectors. When I opened he boxes I noticed right away that the ECU was very different. Research says it is SD and came from a 92 Camaro and that they were extensively used in the LTCC conversions. The question? Will this ECU work with the opti and what do I need to do to get it to work with my LT1?
rich5368
04-29-2012, 05:10 PM
Install and tune for your ECU and drop that piece o crap on ebay for $50
fuzzyjk
04-30-2012, 07:13 PM
So it will not work? The custom harness that cam with the supercharger and the ECU is pin'ed for this ECU. Anyway of working this set up?
rich5368
04-30-2012, 09:41 PM
That I don't know. Gonna have to do some reading on your end. Who made the supercharger kit? Call them up and find out.
FSTFBDY
05-12-2012, 08:40 PM
What car you trying to put it all in? More info needed on your end.
Im running a stock 92Z setup in my vert. but Im also running custom code for boost also. Drilled intake and MSD Pro Billet distributor. works out for me but not worth the swap if your running a lt1 setup anyways.
why not just put the SC setup on what you have and get your current setup tuned for it.
fuzzyjk
05-13-2012, 09:31 PM
I purchased a supercharger kit used for a 94 LT1 F-Body. It came with a hi-power coil and a custom tune. It still runs the opti. Will this older ECU be useable?
whytryz28
05-13-2012, 09:37 PM
93 Cars came SD tuned also.
FSTFBDY
05-14-2012, 07:25 PM
Are you putting it all back in a 94 fbody?
IF it all came as a kit and was running in someones elses car. Then I would assume it will work if your putting it back in an fbody also.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
