had ticking noise.... now went away??
Old 04-30-2012, 08:17 PM
00Z28 ls1's Avatar
Default had ticking noise.... now went away??
ok to start with i changed my oil today. ran same oil ive ran in car befor with no issues. and went for a a little drive and ran into a vw gti. so we ran from a 50 up to about 90 and i shut it down, pulled off and shut car off and started to talk to the guy. the car was fine when i shut it off. Upon start up it had a ticking sound from the drivers side( no it wasnt piston slap) and car still seemed to run fine and everything else. half way home it just stoped and everything sounded fine. let car cool off and started it again about 40-45 min after i got home and nothing idled a quite as it always has.Could this be a lifter issue and could it be related to the new oil in anyway?? im just worried that its a rod or somthing but thats somthing that would not go away right?
Old 04-30-2012, 08:20 PM
xBrandonx's Avatar
Exhaust leak?
Old 04-30-2012, 08:32 PM
00Z28 ls1's Avatar
no its was comming from the motor. i just dont know if it was a minor thing or somthing i should be really worried about.... guess ill just have to see what tomarrow brings,
Old 04-30-2012, 11:42 PM
Unforgiven1's Avatar
I've dealt with what I would consider excessive valvetrain noise for quite some time myself. I've always had a feeling as though there was something wrong. I also suspected that it was possibly a bent rod. Went though that and found nothing. Still replaced with some stockers. Noise still there. Too lazy to follow through with anything else since. Car still runs strong to this day but I'm sure something isn't right. So...I've decided it's time to deal with it and figure out whats going on and I'm starting out with a compression and vacuum test. I would suggest the same to you. If you find there to be some suspicion of damage based upon these then you should probably further it by running a leakdown test to help pinpoint what you are dealing with.
Old 05-01-2012, 07:30 PM
00Z28 ls1's Avatar
car ran great with no ticking or anything today... hmm guess im lucky for now. its weird to me that it happend for about 25 min and then just stoped.
Old 05-01-2012, 08:23 PM
Thumbs up
Trust your gut.
