LT1-LT4 Modifications - Is swapping ls1 driveshaft a direct replace
shaq_2500
05-03-2012, 05:00 PM
Trying to see if I need anything to swap a ls1 driveshaft in an lt1 car
Camaro350Z28
05-03-2012, 05:25 PM
same. 82-2002 are all the same lengths no matter the tranny
F0x Slaughter
05-03-2012, 06:58 PM
As said its been covered. Yes it is.
RamAir95TA
05-03-2012, 07:21 PM
If you like a weaker-than-stock replacement it sure will work. :)
F0x Slaughter
05-03-2012, 07:37 PM
If its weaker than stock why do people do the swap? Is it because the LS1 driveshaft is better balanced then the LT1?
Toronto LT1
05-03-2012, 07:47 PM
Aluminum LS1 driveshaft is a bit lighter than the stock LT1 steel.
96RamAirTA
05-03-2012, 07:49 PM
Lighter for one
shaq_2500
05-03-2012, 08:30 PM
I thought maybe the yoke was different
bizerk1
05-03-2012, 11:43 PM
I dont think there differnt, from what I have heard just a good idea to change while you change the driveshaft. Lighter so it spins faster, but if your putting down power the lt1 would be better option
lt1slowz28
05-04-2012, 02:28 AM
LS1 is weak, but for stock and daily driver applications works fine, also is a little smoother at higher rpms
Rodinator1234
05-04-2012, 06:41 AM
I just put one in my car plug and play.
tbag_skywalker
05-04-2012, 07:20 AM
Its a direct swap between the two shafts. LS1 ds is lighter and a little smoother at high speeds, but the steel LT1 is stronger.
Make sure you have the aluminum shaft under the car with you and ready when you pull the steel one out of the tranny, as some tranny fluid might spill out depending on how forward the car is tipped on the jack stands.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
