Is swapping ls1 driveshaft a direct replace
Old May 3, 2012 | 05:00 PM
shaq_2500's Avatar
Default Is swapping ls1 driveshaft a direct replace
Trying to see if I need anything to swap a ls1 driveshaft in an lt1 car
Old May 3, 2012 | 05:25 PM
Camaro350Z28's Avatar
same. 82-2002 are all the same lengths no matter the tranny
Old May 3, 2012 | 06:58 PM
F0x Slaughter's Avatar
As said its been covered. Yes it is.
Old May 3, 2012 | 07:21 PM
RamAir95TA's Avatar
If you like a weaker-than-stock replacement it sure will work.
Old May 3, 2012 | 07:37 PM
If its weaker than stock why do people do the swap? Is it because the LS1 driveshaft is better balanced then the LT1?
Old May 3, 2012 | 07:47 PM
Toronto LT1's Avatar
Aluminum LS1 driveshaft is a bit lighter than the stock LT1 steel.
Old May 3, 2012 | 07:49 PM
96RamAirTA's Avatar
Lighter for one
Old May 3, 2012 | 08:30 PM
shaq_2500's Avatar
I thought maybe the yoke was different
Old May 3, 2012 | 11:43 PM
bizerk1's Avatar
I dont think there differnt, from what I have heard just a good idea to change while you change the driveshaft. Lighter so it spins faster, but if your putting down power the lt1 would be better option
Old May 4, 2012 | 02:28 AM
lt1slowz28's Avatar
LS1 is weak, but for stock and daily driver applications works fine, also is a little smoother at higher rpms
Old May 4, 2012 | 06:41 AM
Rodinator1234's Avatar
I just put one in my car plug and play.
Old May 4, 2012 | 07:20 AM
tbag_skywalker's Avatar
Its a direct swap between the two shafts. LS1 ds is lighter and a little smoother at high speeds, but the steel LT1 is stronger.
Make sure you have the aluminum shaft under the car with you and ready when you pull the steel one out of the tranny, as some tranny fluid might spill out depending on how forward the car is tipped on the jack stands.
