Timing chain issues
Timing chain issues
Hey is it normal to have slack with brand new ls2 chain? i have enough slack to make me concerned and im strongly considering returning the chain and buying the timing set. Or is the slack normal A friend of mine just installed a new cam sprocket and ls2 chain and his is tighter. Is has a little slack but one side stays tight always, where as mine is loose on both sides. Could my sprockets be worn??
A lot of slack is normal. I prefer to use new sprockets but they don't reduce the amount of initial slack, only the accumulation of additional slack over time.
https://ls1tech.com/forums/generatio...uch-slack.html
