LS7 Lifters, pushrod size? 243's milled
ok so i got installed a g5x3 114 cam on my camaro 2002, which has the 243's heads, those heads were milled 10mm, thats what i was told by my uncle who went and got the job done with a friend of his.
now i want to replace lifters and pushrods, im going to get the LS7 lifters, but i wasnt sure how to know what pushrod size to get, any help would be greatly appreciated.
thx
thx
.07 milled off equals 1 cc
Stock 243 are around 64-65 cc's.
So 10mm doesnt sound right?
The heads should have had Their CC measured first, then a test mill of .07 to make sure it's cutting correctly. then finish it to the desired thickness...
anyway pushrods are the last thing you should buy, get your lifters, then get a pushrod checker (20$ off one of the vendors to the right )
then you'll know exactly with no guessing.
i will ask tomorrow to make sure, but lets say it was .01 what would be a good pushrod size, using ls7 lifters, im not sure but a friend of mine said that the ls7 lifter are slightly longer?
