H/C/I guess!
Old 05-12-2012, 05:48 PM
CWIZZLE's Avatar
Default H/C/I guess!
Been a member for awhile, mostly just on here for input and ideas. I have a 2000 ss with 85k on the clock. Car is in the shop atm getting afr 225's, tsp tsunami, fast 102/102, 42lbs injectors, and a good tune. I have full bolt-ons, headers, lid, pully, exhaust, plugs/wires, 10 bolt 4:10's tru trac, LS2/LS7 fly-clutch, subframes, LCAs, panhard. Wondering what i can expect HP/TQ. All the searches say around 420-480 rwhp some near 500. Let's hear some input!
Casey
Old 05-12-2012, 07:08 PM
TransamGCS's Avatar
i would say your in the right direction i would guess around 450 ish if you look at my sig i made 465 rwhp but dynos are so subjective, good luck with your upgrades you should be real happy
Old 05-12-2012, 07:28 PM
TurboStangJON's Avatar
I wouldn't worry about the numbers it puts down on a dyno. I would worry about the number it lays down at the track because that's the real indication of how much power you're making. I made 420 on a dyno but have trapped the highest of 132MPH in the 1/4 with a H/C/I 346 naturally aspirated.
Old 05-12-2012, 09:28 PM
CWIZZLE's Avatar
Yea this being my first big power adder upgrade, im excited. Ill keep everyone posted and what it puts down. Should be on the dyno this wed or thursday via lethal performance in San Antonio. Also for the oil pump.....planning on going turbo later, high pressure or high volume?
Old 05-13-2012, 01:51 AM
ls1 1990 VN's Avatar
High Pressure!
Old 05-13-2012, 06:41 AM
prokilllsx's Avatar
Old 05-13-2012, 12:14 PM
CWIZZLE's Avatar
Can you spin the tsunami past 6800rpm??
Old 05-29-2012, 01:58 PM
CWIZZLE's Avatar
Changed to prc 227's at last minute, dyno tomorrow at 3pm!!
Old 05-30-2012, 08:55 PM
CWIZZLE's Avatar
Low numbers.....416/407.....still have stock maf, and lid feeding the fast 102/102. Air density was terrible today, humid and hot, calculated to about 3412ft elevation. Pulls like Hell up top. Have pics and vids coming soon along with dyno graph.
Old 05-30-2012, 09:03 PM
garygnu's Avatar
I would have used a big EPS cam or a Trex cam.you will need a better rear end.
Old 05-30-2012, 09:14 PM
CWIZZLE's Avatar
Tsunami is pretty big, hoping the Detroit tru trac will hold for a little while, no track that's for sure!!
Old 05-31-2012, 10:38 AM
Like I said before I wouldn't get caught up in the dyno numbers. I had the same results through a stock MAF in hot weather.
Old 05-31-2012, 11:45 AM
CWIZZLE's Avatar
Thing I'm worried about is the cam. I've heard many tsunami cams online and in person and it lopes pretty hard. My car at a idle almost sounds like stock and its on a 111 lsa! Will get try to get vids up tonight.
Old 05-31-2012, 12:42 PM
Rise of the Phoenix's Avatar
What is your idle set at? Those numbers seem low to me. Who did the tune and what kind of dyno was it?
Old 05-31-2012, 08:16 PM
02sslayer's Avatar
i have ther tsunami with prc 2.5 ls6 and i made 426 on a mustang dyno. track, 12.1@116, keep in mind this is with the 10 bolt and a sticking clutch pedal. i think i could get an 11.8 or 9 with a better clutch @ 117-118
Old 05-31-2012, 08:26 PM
BrntWS6's Avatar
Yeah, Tsunami cam is like a 235/240 so it's definately not on the small side. I have the Torquer V3 which is also on a 111 lsa and my idle is set at 900rpms, no question there is a cam in there.
It is quite a bit low....those are close to cam only numbers.
Old 05-31-2012, 10:37 PM
CWIZZLE's Avatar
Dyno jet, it was a very hot, muggy, humid on dyno day. Lethal performance tuned it in San Antonio. Just doesn't seem right to me. Going to call tsp tomorrow. Only thing I want to change soon is a new lid and 100mm maf, maybe the stock maf is choking it up?????
Old 05-31-2012, 10:39 PM
CWIZZLE's Avatar
Idle is about 850-900.....I was expecting atleast 450 rwhp! Stingy dyno??
Old 05-31-2012, 10:51 PM
Sladester2's Avatar
Should not sound even close to stock at idle.
Old 05-31-2012, 11:01 PM
CWIZZLE's Avatar
I know! I have the cam card. Waiting on my camera to post the vids I have. With long tubes, ory, dynomax bullet (hollow, looks like an expanded piece of exhaust tube) out to duals at bumper. No cats, no muffler, you would think you would hear the lope but hardly can at idle, at WOT its loud as Hell. Everyone will see the idle vid soon.
Quick Reply: H/C/I guess!
