Gears & Axles - Ebay 9 inch anyone have one?
View Full Version : Ebay 9 inch anyone have one?
just1news6
05-17-2012, 03:34 PM
http://www.ebay.com/itm/9-inch-Ford-Chevy-Camaro-F-body-93-94-95-96-97-98-99-00-01-02-Rearend-Housing-/251059574667?hash=item3a7451178b&item=251059574667&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Found these on Ebay just wanted to know what yall thought im looking to replace my 10 when it breaks. :judge:
SS SLP2
05-17-2012, 04:56 PM
I bought from Bob ( he helps keep ls1tech going )
http://shop.brutespeed.com/82-02-F-B...ar-Ends_c5.htm
Link to Moser 12 Bolt and 9 Inch Rears with Pricing
good luck, Johnny
bwkmaro
05-17-2012, 05:27 PM
your not really saving much and getting a reman unit where any of the guys on here use new ones
LS-ONE_DAY
05-17-2012, 05:30 PM
I believe people have those rears whether or not they got them from Ebay I do not know. From what I remember hearing QP quality isn't as good as Moser/Strange/etc. They usually have some minor fitment issues which the others generally don't
b_evans06
05-17-2012, 05:36 PM
I have a quick performance bolt in 9" in my gbody. Bolted up fine and I am happy with it. It has been in the car a year with no problems.
blue98Z
05-17-2012, 05:41 PM
This^^
I've had two 9"'s. Both I ordered through Bob at Brutespeed. He takes great care of his customers. First one was perfect, the second one Moser sent the wrong axles. Called Bob and bam Moser called me the next day and had the new axles to me in about 3 days. QP is just another company. Not sure on their customer service but, I've helped install one of their rears and it needed some tweeking here and there to fit correctly. They order their axles from Moser also. Don't know about you, but if I pay that much for a bolt in/on item I expect it to do just that. No extra modifications should be done on my end. Other than the E-brake bracket. I think that's a mod on all rears though. Most race cars I've seen don't use an e-brake so I'm guessing that's why it's not an option.
kkslds
05-17-2012, 06:14 PM
That doesn't include a center section. You can get that same package ( housing/ axles) from moser for just a couple hundred more. Not only would you get better quality, but im sure the rear end would retain its value better if you ever decided to sell it being a moser instead of a brand most people have never heard of.
355z28
05-17-2012, 06:27 PM
The QP comes with awesome LCA relocation brackets standard at no extra cost, also comes with drain and fill plugs at no extra cost.
The quality of my rear from them was awesome. The welds looked fantastic. The only fitment issue I can was the bolt hole for the panhard bar was just a little too small. other then that it bolted up and fit great.
t/a98
05-17-2012, 07:05 PM
Aren't quick housings re build old ford housings where moser makes them new? I am in the market too and was all over quick till I priced moser. One of the sponsors sells the moser, maybe brute speed idk, at a little over a hundred bucks more than quick. It made my mind up quick. Now if I can find an affordable center.....
tt383lt1
05-17-2012, 07:13 PM
i bought one 4 years ago and not one issue. and i beat the living shit out of it. the only problem i had is they sent me the 3rd gen instead of the forth ge. they shipped the new one really quick. i would recomend them any day. i also bought my bolt thrru case from them too. and i would recomend getting the back brace too.
tt383lt1
05-17-2012, 07:15 PM
i got told they get the middle section and weld the axle housing on. so im guessing the new housing
355z28
05-17-2012, 08:23 PM
They offer it 3 way.
The standard is an old housing but they slide the axle tubes in further for added strength, they also can use a brand new housing and do this as well.
and they also offer a heavy duty one for $100 more that looks awesome.
http://i49.photobucket.com/albums/f289/cavytek/new_housing_center1.jpg
zracer323
05-17-2012, 08:46 PM
If you want a quality bolt in housing with any options you want just go with Midwest Chassis.
Bob@BruteSpeed
05-18-2012, 06:10 AM
good luck, Johnny
Thanks, I really appreciate it. Sponsorship on here is very expensive. Bob
Bob@BruteSpeed
05-18-2012, 06:12 AM
This^^
Thanks, I really appreciate the orders! Bob
Cape T/A
05-19-2012, 02:33 PM
you get what you pay for, if its cheap its for a reason. Ive seen way to many of my friends get burned by buying a cheap rear end.
WS6 SRT-8
05-20-2012, 12:34 PM
Listen to these guys. If I didn't buy from Midwest, I would've bought from Brutespeed.
