I have a lingenfelter 2 step LNC-003. Do I use both stages or just the first stage. What would be the advantage of using the second stage? thanks
You could use 1 stage or both. It is completely up to you. Some people like to use the secondary stage for the burnout box or as a rev limiter (some aftermarket engine management systems do not have a built in rev limiter).
Ryan
oh ok,GREAT!! what do you recommend? Thanks for the info as well.
