Fueling & Injection - ls2 rail, ls1 injectors, fast 92mm intake help
gsd2000
05-23-2012, 02:37 PM
I have an 2004 monaro ls1 M6, in the UK.
Ive just installed a FAST 92mm intake, using my stock ls1 fuel rails and injectors but the injectors dont quite look right. It looks like the fuel rail crossover pipe is catching forcing the injectors up.
I have a spare ls2 intake with injectors and rail and was wondering is it possible to use an ls2 fuel rail, with ls1 injectors, with a fast intake designed for an ls1/6.
If so would an ls2 fuel rail provide more clearance mainly over the central crossover section than an ls1 rail?
I can try and add some photos if it helps to explain the question.
some photos
http://i28.photobucket.com/albums/c249/g_s_d2000/IMAG0246.jpg
http://i28.photobucket.com/albums/c249/g_s_d2000/IMAG0245.jpg
Do the injectors look low enough?
A couple just seem to sit a little lower to me
http://i28.photobucket.com/albums/c249/g_s_d2000/IMAG0244.jpg
http://i28.photobucket.com/albums/c249/g_s_d2000/IMAG0241.jpg
http://i28.photobucket.com/albums/c249/g_s_d2000/IMAG0240.jpg
http://i28.photobucket.com/albums/c249/g_s_d2000/IMAG0239.jpg
thanks
