Help with injector connector
Old May 23, 2012 | 12:36 PM
BigV8LS3's Avatar
Default Help with injector connector
I'm working on my 99 5.3 silverado and can't seem to get the connectors off the injectors. here are the pics first one is before i pull up on the gray clip and the second is after I've pulled up on it and push the black tab. I'm i not pulling the gray one up far enough? Thanks
Old May 23, 2012 | 01:10 PM
BigV8LS3's Avatar
Are the pics showing up?
Old May 23, 2012 | 01:22 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
You should just squeeze the black tab and pull. Sometimes those truck clips are a bear. Push the whole clip in to take off any pressure, squeeze, and pull it out. It might just take some good effort.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 23, 2012 | 02:01 PM
BigV8LS3's Avatar
Thanks for the reply. I thought I was doing it right with the retainer, it being a bear ain't telling half of it. I'm just down to the connectors of pulling this intake. Thanks again!
Old May 23, 2012 | 03:25 PM
BigV8LS3's Avatar
I finally got them. Once I got one off and saw what was going on, I ended up using a curved pic under the connector to help release the clip on the injector.
