Hp Tuner help
Old 05-29-2012, 06:56 PM
bandit383's Avatar
Default Hp Tuner help
got a Tall Deck LSX with a SD tune and the timming is bouncing around at WOT with no knock... see attched log file
File Type: hpl
Old 05-30-2012, 05:55 AM
ScottyBG's Avatar
It looks to me that it is roaming between 28.5 and 30.5 degrees. What does your Main spark vs Air Mass vs RPM table look like in this operating area? If it ranges between 28 and 31 in the area of operation of your log, this would be normal as it would interpolate between the values as it moves from one cell to another. This looks pretty normal to me, if you want to keep it dead constant you will need to have the entire table be 1 number, like 30 or such, throught that range it pulls through in terms of g/cyl across the RPM range of your pull. This will let you see a constant number on your log but it probably won't run any better.
Old 05-30-2012, 10:18 AM
bandit383's Avatar
The table in the said range is set to 30*.
Old 05-30-2012, 10:29 AM
edcmat-l1's Avatar
How bout posting the tune? Could be a few tables coming in to play.
Old 05-30-2012, 07:11 PM
bandit383's Avatar
see attched
File Type: hpt
Old 05-30-2012, 07:21 PM
MUSTANGBRKR02's Avatar
VA Speed tune? This could get interesting.
Old 05-30-2012, 08:04 PM
bandit383's Avatar
Also car has been put into SD but wont run without MAF. Isnt a SD tune suppose to del the need for a MAF?
Old 06-01-2012, 11:23 AM
bandit383's Avatar
Any inputs?
Old 06-01-2012, 12:03 PM
LS1TECH Sponsor
foff667's Avatar
on the LS1's half a degree gets lost on the conversion from the raw spark variable inside the code to the PID variable used for scanning, with that said you might consider logging burst knock retard and seeing that your o2 readings & trim readings aren't showing any useful data you might consider deleting them, this should help getting a faster frame rate as well.
Old 06-01-2012, 01:57 PM
edcmat-l1's Avatar
Would like to see data log to go with the tune. What's the compression of that motor? Kind of a lot of timing, 31 degrees. Interesting looking timing tables.
Old 06-01-2012, 02:02 PM
bandit383's Avatar
14:1 the log posted goes with the posted tune. Running c16
Old 06-01-2012, 08:03 PM
edcmat-l1's Avatar
That's very strange. Tune is def setup in SD. Is this maybe a 5 wire MAF?
Old 06-01-2012, 10:10 PM
bandit383's Avatar
It is a 5 wire but I've got the adapter to a 4 still using stock air temp sensor
Old 06-01-2012, 10:19 PM
edcmat-l1's Avatar
Then it should run without the MAF plugged in.
