column lock fuel disable-abs dtc
This is a unique setup because it's not really the 02 Corvette that the PCM is out of...it's a 63 Nova with an LS3 and LS1/LS2 conversion adapter (for different crankshaft reluctor). The car (PCM) was dyno tuned a few weeks ago and has run fine until battery was disconnected for starter replacement, then this happened. The VTD and column lock had to have both been disabled (in PCM) for the PCM to allow fuel before, why would it have changed when battery was disconnected? Has anyone run into this type of problem? This is the only abnormal reading I was picking up...maybe we're just overlooking something else?
