LS4 Performance - What is the best replacement manufacturer for hub assembly?
straitchev
05-30-2012, 06:48 AM
Need to replace my front hub assembly. Dont want to go with a cheap duralast replacement....I traditionally replace all parts with ACDelco but wondering if there was a preferred manufacturer.
Thanks
hazards280
05-30-2012, 10:52 AM
I really like Timken. I think they have lifetime warrantys too.
JessmoMonteSS
05-30-2012, 11:22 AM
x2
Never had issues with a Timken. No lifetime warranty but they will last a hell of a lot longer than any of the cheaper brands.
The Guz
05-30-2012, 02:17 PM
I have been seeing guys on other w-body forums starting to go with SKF as the timkens that they have been using are not lasting that long. Just something to consider when doing your reasearch.
Andrew91PGT
05-31-2012, 11:11 PM
I just ordered skf bearings to replace my oem's at 91,000 miles. They are still tight but I'm getting an Abs code for the front right sensor.
Skf actually put "expected life span of 100,000 miles" if you check the rockauto.com online catalog...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
