What is the best replacement manufacturer for hub assembly?
Need to replace my front hub assembly. Dont want to go with a cheap duralast replacement....I traditionally replace all parts with ACDelco but wondering if there was a preferred manufacturer.
Thanks
Thanks
I just ordered skf bearings to replace my oem's at 91,000 miles. They are still tight but I'm getting an Abs code for the front right sensor.
Skf actually put "expected life span of 100,000 miles" if you check the rockauto.com online catalog...
