charlie97z28
06-01-2012, 11:47 AM
Jus picked up a fast setup with aeromotive rails what size fitting do I need to run braided line from the factory filter on and what size line should I run -8 or-6
Old Geezer
06-01-2012, 02:04 PM
A -6 should do the job, unless you are planning to feed big HP.....
Summit has the adapters w/ the screw in retainers for both the inlet, outlet, and the return lines.
5/16 return is 644113 Black Blue is 644110
3/8 filter in is 644123 Black Blue is 644120
Filter out is 640940 Plated
We use a combo of colors to ID the return vs the inlet....
